Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-21-2010, 10:11 AM
Jeremy Morrow Jeremy Morrow is offline
Exclamation RE:99 Ford Stang 3.8 :)
This has been like this since I bought it.
Ummm Question 1 is: When I turn my A/C on my car wants to die runs at about 500-600rpm...When I turn it off the idling jumps to 700-800 hundred.
Also Question 2: Just started today July 21 2010 @ around 8:30am MST
When i come to a stop at a light or anywhere for that matter it dies. I have to keep my foot on the break and push in on clutch its a hasard waiting to happen please help if you can Thanks for your time.
Jeremy Morrow
Last edited by Jeremy Morrow; 07-21-2010 at 10:12 AM. Reason: Forgot to add Manual Transmission 5spd
Old 07-21-2010, 05:38 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 99 Ford Stang 3.8 :)
Not sure if this is normal or not on the 3.8L. I would assume the IAC should open a little more to increase idle airflow to bring the RPMs back up.
Correct me if I'm wrong, but isn't it normal operation to have to depress the clutch and brake when stopped in a manual? (And yes I can drive a manual).
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 07-22-2010, 05:04 AM
Davescort97 Davescort97 is offline
Escort guy
I'd go with Blue)(Fusion. Your IAC (Idle Air Control) needs to be replaced.
