Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 07-21-2010, 07:54 AM
2kTrailBlazer's Avatar
2kTrailBlazer 2kTrailBlazer is offline
Send a message via AIM to 2kTrailBlazer
Loud, high pitched whistle
have a 97 town car, upon start up there is a loud, high pitched whistle/hum(not sure how to describe it) type noise comming from the engine. Possibly a pulley?? it doesnt sound anything like a serp belt its much louder and a different sound. I cant pinpoint where it is comming from. It does sound like the front of the motor. Any body have any ideas? Any input would be appreaciated thank you
Old 07-21-2010, 08:14 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: Loud, high pitched whistle
Open the filter airbox. Is the noise coming from there? If so, you need to replace your Idle Air Control (IAC) Valve.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 07-21-2010, 10:51 AM
All2kool's Avatar
All2kool All2kool is offline
If the noise is RPM related, then I'd have to guess a Power Steering Pump Pulley as the noise you describe is exactly that of a Jeep GC I owned.
Old 07-21-2010, 06:35 PM
homeskillet43 homeskillet43 is offline
Send a message via AIM to homeskillet43
You have the same issue as me. Check your fuel pressure regulator. That was my issue. That sound is annoying.
Old 07-21-2010, 10:22 PM
Kitt1993's Avatar
Kitt1993 Kitt1993 is offline
Mine was the plastic tube that goes from the back of the engine to the IAC. but I have a older engine design than yours. If you raise the idle up in PARK, dies it go away?
Nick names for my Car....
Abe Lincoln, opcorn:
The President,
Lucky Number 5
Old 07-21-2010, 10:49 PM
hey guys thanks for all the tips so far. It doesn't go away as I raise the rpms. It seems to get a little worsebut its hit and miss while I raise the rpms
Old 07-22-2010, 12:49 PM
Attached you will find the fuel pressure regulator. Try that and see if that is what the noise is. That was my problem.
