Old 07-20-2010, 11:01 PM
z66 z66 is offline
96 Grand Am 3100 No Spark
Purchased a 96 GA 3100(M vin) on Craigslist with a locked up engine for my grandson so he could learn the internals of the engine and give him some experience. The engine had spun #1 rod bearing, and broke the camshaft in half due to lack of oil.
We purchased a 3100(M vin) from a wrecked 98 Lumina, replaced the LIM gaskets and installed the engine. Everything went well with the exception we did not get the negative battery cable on the transmission stud when first trying to start engine. It did backfire a couple of times, but would not start, after rechecking all found and installed cable.
Now we are getting no spark when cranking, we did leave both crankshaft sensors, the camshaft sensor,coil and wires, and injectors, from Lumina.
Things checked so far:
1. 12v at ICM, pink and black wires.
2. Replace 7X CKP sensor, still only show 1.1 AC volts at plug disconnected from ICM when cranking, Alldata online states I should be getting 2 volts???
3. Removed ICM and took to Autozone, they checked with tester, checked ok after 3 test cycles.
4. Removed one of the coils and placed test light between primary coil terminals on ICM, NO light when cranking, also tachometer doesn't move when cranking.
5. Coils all check out around 6K ohms on secondary side.
6. Have removed top air cleaner housing and sprayed starting fluid while cranking, no backfire.
7. Compression around 150lbs.
8. Theft light comes on and stays on when cranking, no blinking, tried leaving ignition on for 12 minutes, light did not go out. No chip on key.
9. The original fuel injector harness under the upper intake had to be used because the lumina harness had another large connector on it.
I feel the problem is no spark, because starting fluid has no effect and the test light doesn't light up at primary coil terminals on ICM when cranking. My understanding it will start and run without the cam or front crankshaft sensors, correct me if I am wrong on this.
I hate to spend money on a camshaft sensor or a front crankshaft sensor if it doesn't need them, the old crankshaft sensor that came out of the block has the same ohm reading as the new one from Autozone.
Any help would be appreciated.
Old 07-21-2010, 04:04 AM
3100 3100 is offline
Banned
Re: 96 Grand Am 3100 No Spark
- good work that is what I like to see.
- icm has 3 conectors (2 on the right and one on the left). Check that one on the left is plugged in.
- you are correct this engine will start and run without cam signal or 24X sensor that is located by the balancer.
- the most important and the critical sensor for starting is 7x ckp with purple and yellow twisted wires. This connector should be connected on the right side of the icm not on the left. So check that you did not accidentially swithc connectors.
- disconnect the two pin connector at the right side of the ICM with purple and yellow wires, connect DVOM set to mV AC, ask someone to crank the engine while you are observing AC voltage it should be in the range of 200 mV AC. If you get some mv AC that is good sign. Now if everything was connected correctly and if you tested your icm the way you said with the test light then ICM is bad. Use icm from the old engine then.
- so if you tested icm by removing coils and then bridging male terminals for each of the coils with test light and looking for test light flashing while someone is cranking that is correct. No light means bad ICM (if ckp is sending signal as I described in the test above).
keep us posted
Old 07-21-2010, 09:44 AM
z66 z66 is offline
keep us posted
Thanks so much for your help,
I removed all coils, and plugged in ICM off of old engine, then bridged male terminals with a test light. No terminals would flash light, added a ground to the base of ICM with a jumper wire to - side of battery, still no light.
Disconnected six wire connector on ICM to PCM, and now test light flashes when cranking, tried both ICM's, the same on both.
The plug on ICM I disconnected has 4 wires:
1. A - Tan/Black Stripe
2. B - White
3. C - Empty
4. D - Empty
5. E - Purple/White Stripe
6. F - Red/Black Stripe
Autozone online Fig. 4 Ign sys diagnosis 3.1 engines shows:
1. A - 424 Tan/BLK to C28 on PCM Ignition Control
2. B - 423 WHT to C27 on PCM Ignition Bypass
3. C - 121 WHT - Tach Signal - Empty on my connector
4. D - Empty
5. E - 430 PPL/WHT to C30 on PCM 3x REF HIGH
6. F - 453 RED/BLK to C31 on PCM 3x REF LOW - Noticed this is also terminal C on the CMP and 24x CKP Sensors
How should I proceed?
Could I have damaged the PCM when trying to start with the - battery cable disconnected at the transmission stud?
Old 07-21-2010, 12:11 PM
Banned
do you have scanner?
-ignition key into run position check for codes
- if you have all data you will notice that az and all data's el. diagrams for the same year and model show different pcm pin#.
Check ground 110 that main engine ground to the left of vacuum modulator on the engine block, (so make sure there are no loose black wires in that area)
Disconnect negative battery cable, disconnect the pcm (blue connector) (you will need 7mm socket) , then disconnect 6pin connector at the ICM, test for continuity at the 6 pin connector between each of the wires to make sure there are no shorts. Then check from terminal B of the ICM 6 pin connector to terminal 53 of the PCM blue connector (both should be white wires) - so check for continuity to eliminate open. Also terminal A at icm with pin 52 of the pcm blue connector (both ends should be tan/black)-check for open the same way. And do the same for terminal E with pin 44 - make sure you have same wire colors at both ends. Terminal F with pin 45 do the same way.
if your multimeter black and red wires are to short for this testing, use jumper wire with alligator clips at both ends to extend one of the testing leads.
Old 07-21-2010, 12:42 PM
z66 z66 is offline
Thanks again for your help,
I checked out a scanner at autozone a few days ago, did not show any codes so I took it back.
I went to library and printed out the alldata "Engine cranks, But will not run" troubleshooting chart, I didn't realize that the 2 electrical diagrams were different until you pointed that out.
I have noticed some other discrepencies in the Autozone online charts(specifically checking the camshaft sensor states "Place a socket and breaker bar on the crankshaft pulley bolt and rotate engine by hand. Observe th volt meter and verifty the the voltage singal varies from approximately zero volts to slightly less than supply voltage. The voltage will switch on when the target passes the sensor and will show little or no voltage when the target is past the sensor." On mine it would show voltage until is passes the target then goes to zero, just the opposite.
I have checked all the grounds at the transmission stud next to the vac modulator, this is where I previously noticed we had left the negative battery cable off.
Old 07-21-2010, 12:51 PM
Banned
please read my previous post again, I think that I was editing it while you were writing your last post.
Old 07-21-2010, 04:55 PM
z66 z66 is offline
Disconnected battery and pcm, checked for grounds on terminals A,B,E,&F of ICM connector, found no grounds, then checked for continuity between same to corresponding terminals on pcm plug.
All checked good for continuity and no grounds.
I previously removed all the coils from the ICM and I would be able to get my test light to flicker when I would crank the engine only if the 6 wire connector to the ICM was unplugged, if I plugged it in I would get no flashing light across the primary coil terminals.
I also noticed when I reinstalled 2 of the 3 coils I would not get a test light to flash on the terminal with the coil off either way..either 6 wire connector on or off. In other words is it necessary to remove all coils to test if the ICM is sending signals to to coils?
Thanks again "3100" for your help in troubleshooting this.
Old 07-21-2010, 05:50 PM
Banned
- when you have coils installed and all connectors plugged in at the icm, what happens when you remove one of the spark-plug cables from the spark-plug and insert screw driver into the boot? No spark at all?
Old 07-21-2010, 10:16 PM
z66 z66 is offline
No spark at all
Old 07-22-2010, 12:48 AM
z66 z66 is offline
On the PCM, is all the programming done on the prom?
Can I purchase a used ECM with the same Service # then install my PROM in it?
I have about came to the conclusion that I may have damaged the PCM.
Old 07-22-2010, 01:46 AM
Banned
That is what I was thinking, but not that you damage it, it could be that pcm did not work at first place, and I did not want to blame pcm right away. You can buy used pcm at yunk yard as long as the year and accessories are about the same as your 96 GA.
not expensive at all, bought myself one just for testing purposes and as a backup and it cost me $20 from junk yard.
Old 07-22-2010, 08:29 AM
z66 z66 is offline
I know I need the same Service # of the computer I get at the junk yard.
What about the BSKS that is after the Service #, isn't that the programing of the prom?
What I am would like to confirm is:
1. If I buy a 16211539 BSKS, could I just install it, prom and all, and be the same as mine? or
2. If I buy a 16211539 xxxx, can I just remove my prom and install in purchased computer and will that work also?(assuming the prom is good in my computer now)
I understand if a dealer done some updates that there may be some minor differences in the software, but is the BSKS what the factory put in my 96 GA, designate the options it came with?
Thanks 3100 for your help on this, if this car had a distributor and a carb I could handle that.
Old 07-22-2010, 08:48 AM
Banned
I wold get the complete unit. I did not have to do anything with prom. When you install new pcm you will have to do relearn procedure, attempt to start and leave key in run position until security light stops flashing, then start.
-try this relearn procedure again. So attempt to start and just leave key in run position til light turns off or stops flashing don't remember exactly.
-don't forget to connect all connectors at the ICM before doing this.
- you said that you already waited 12 min
try again and wait longer
Old 07-22-2010, 11:25 AM
z66 z66 is offline
I found this:
GM:
10 Minute Learn Procedure
Tools Required:
None
Turn ON the ignition, with the engine OFF.
Attempt to start the engine, then release the key to ON (vehicle will not start).
Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF.
Turn OFF the ignition, and wait 5 seconds.
The vehicle is now ready to relearn the Passlock™ Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
Important
The vehicle learns the Passlock™ Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
Start the engine. The vehicle has now learned the Passlock™ Sensor Data Code and/or password.
With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles.
I did this:
Cranked engine, left key in ON posistion for 20 minutes, THEFT light remained on, Light Stayed ON...never blinked...never went OFF...Turned the switch to OFF, waited for 5 seconds, retried to start...
I also checked the pink wire when cranking at the ICM, voltage at 11.5 volts when cranking. Found these cars had a recall on Ignition switch because the switch would melt due to excessive current through the switch. The engine was locked up when I bought the car, so I sure it had excessive current when trying to crank.
Old 07-22-2010, 12:07 PM
Banned
put the heat on and fan set to to HI, turn switch into run position is blower motor engaging? are wipers working in run position?
- here is one crazy idea but it should tell us if pcm is reading signals. Please try this, but use deep socket for this because you can damage sensor connector. I think it is 19mm or 17mm deep socket that you will need to remove ECT sensor. once you remove ect sensor reconnect the connector, have some hot water ready in a cup, turn key into run position tell someone to submerge only the tip of the sensor that goes into engine block while you watch temperature needle move to hot. This will partially test IPC and PCM. If needle does not move then we will have to investigate further.
Also under the key cylinder is a connector with yellow and black wires that is the pass lock see if it is connected, at that time you will be able to see ignition switch look for signs of melting at connectors.
