Old 07-20-2010, 07:59 PM
dbbygrl dbbygrl is offline
2000 plymouth voyager transmission problem
the problem is now the transmission works only because the car has been shut off since saturday. but when it don't want to shift gears it won't go passed first gear. what could be the problem. could it be limp mode.
Old 07-21-2010, 01:17 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 2000 plymouth voyager transmission problem
Limp mode won't let it shift past second gear and usually turns on the service engine soon (SES) light. You'll have reverse. Sure it won't shift to second gear? Check the fluid level and change the fluid and filter if it's been in there a while. If you see any debrie in the pan more than grit on the magnets head for a shop. Have you checked for codes?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
