Old 07-20-2010, 02:04 PM
harpman harpman is offline
96 Dodge Caravan LE 3.3L brakes gone
Van has been sitting for almost a year while I replaced the fuel pump and filter, cooling fan relay and temp sensor. I went to put it on the road and the brake pedal goes to the floor. No leaks and master cylinder is full. Could it be the ABS relay? If so how do I check it?
Old 07-20-2010, 05:28 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 96 Dodge Caravan LE 3.3L brakes gone
More likely air in the system or the master cylinder.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 07-20-2010, 05:33 PM
Thanks for the quick reply. How would air get into the system when it hasn't been opened.
Old 07-21-2010, 01:37 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
You may not be seeing puddles but have you pulled the drums and inspected the brake cylinders? Even a seep can let air in and given time your pedal can hit the floor. If all looks good I'd opt for a new master cylinder. It's probably leaking past the internal seals.
Just a little background info: http://www.aa1car.com/library/bfixes.htm
Old 07-21-2010, 03:30 PM
I tried to bleed the master cylinder but that didn't help. Will bleed the system and check the rest.
