Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 07-20-2010, 07:58 AM
Panoz Paul Panoz Paul is offline
More Detail Wanted !!!
O.K. The F.I. death spiral is complete ... I'm going to jump to the carb ... Being only "half" of a mechanic ; I've got more questions ... Wiring Demolition ; do you gut it all or just focus on the ECU & work your way out ... I know the basic circuits are fuel pump , fan , ignition / ditributor or I'm I over simpilfying ... Throttle linkage ; Holley makes a nice looking mounting plate & a ball assortment kit ; is this the methodology !?!? Fuel line tie - in ; Ive got my Bosch mounted in the tank , Summit Tech. stateed to use the Mallory In-Line Reg . for $85.00 ... Any other pumbing in - sights ???
Thanks Guys !!! Paul W. / Duluth , MN ph . 218.393.4848
Old 07-20-2010, 02:02 PM
Cobrafang Cobrafang is offline
Re: More Detail Wanted !!!
Give Gary Jones a call tomorrow, we all just got back from Road America. He has done many of these conversions, probably can rattle off the list of stuff you should do and need.
706.592.0060
If he is not at the desk leave a message.
Not sure what is on the plate for him.
-Cobra (A.K.A Tom D)
Racer and Gamer
Panoz GTRA (Mystery Chassis #) (Track Toy)
2001 BMW M5 (Road Toy)
2006 F250 (Car Hauler)
2002 Odyssey (Kid Hauler)
Old 07-20-2010, 10:43 PM
Craig245's Avatar
Craig245 Craig245 is offline
The linkage is trivial. Throw away the cable and get a 3/16 rod. Thread one end and then bend it such that it goes from the carb, a slight joggle to the left and then straight through the firewall, where the cable came out and then through the hole at the top of the gas pedal. Put two nylock nuts on the rod, one on each side of the pedal. Don't tighten them completely because it needs a little play for when you press on the gas. Cut the other end to length and then put on a small spherical rod end and attach to the throttle plate on the carb. Then just check it to make sure that when you floor it, you get full throttle opening. Attach two throttle return springs and you are ready to go. It will never break and it is as direct as you can get.
If you are using the FI pump, you will need to use a regulator with a return line, or you sill burn up the pump. I think it best to get a Holly blue pump and then use a more normal regulator set to 5-6 PSI. The same pump wiring will work for the Holly and you won't need the fuel return line.
Craig
Craig Wright
PGTRA #21
'05 Ford GT
'65 XKE (newest addition)
Old 07-21-2010, 01:19 PM
Talking Re: More Detail Wanted !!!
I ordered all the parts this morning ; A little over $ 1500.00 ; not as bad as thought ; basic direction was Holley 4150 HP mech. , Edelbrock RPM/Airgap , MSD w/ 6AL , plus a buch of little stuff .... I wish that I had not put that much into the F.I . up-grades two years ago ... A big THANKS to all who shared & helped thought this process !!! Paul W. / Duluth , MN .
Old 07-21-2010, 01:39 PM
Hey there are some FI guys that might want that stuff...you should sell it here.
Racer and Gamer
Old 07-21-2010, 09:15 PM
Panoz26's Avatar
Panoz26 Panoz26 is offline
Indeed - I sold all of my FI "stuff" to pay for the new Carb Stuff... was a nice exchange...
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
Old 07-21-2010, 11:08 PM
boothkc boothkc is offline
You will need a new MSD distributor (and wires) to go with the 6AL. If using the stock Explorer you may want a 5500 or similar rev limit chip (they look like fuses and come in a set).
We added aluminun valve covers and a GTS type breather. Sealed dipstick (old style leaks when you corner hard enough....little puff of smoke and your getting fast! put these on the GTS cars too.)
I prefer the Holley Red or Blue fuel pump w/o any regulator. You can remove the return line and cap at fuel cell.
There is a Holley cable adaptor that will let you use the stock GTRA throttle cable and peddle.
You will be amazed at the pile of crap that can come off the car.
I'll shoot some pictures of my GTRA this weekend and post to help.
Kevin
GTS #24 and #25, GTRA #10
Old 07-22-2010, 09:23 AM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
We're running a Holley blue w/ the FPR at the carp. Pro-systems carb w/ an edlelbrock performer air-gap manifold. Running an MSD distributor and ignition box and a rod-type setup from the gas-pedal to the carb. The return is capped on teh fuel cell, but the line is left in place just in case we want to do something different in the future.
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 07-22-2010, 11:25 AM
eric1h eric1h is offline
have you always had the pro-systems carb or did you swap it out? BTW, I LOVE my pro-systems carb, its been flawless thus far!
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 07-22-2010, 01:09 PM
I went to Pro-Systems web page & completed their worksheet ...
They stated, in a E-mail , they would NOT play with me because of my lower HP range ... I'm running 350 ish ... Maybe I should have called them ?!?!
Old 07-22-2010, 02:20 PM
I would call them, or email Patrick, My car was in the 350-400whp range and he built me one and shipped next day!
Email Patrick [email protected] he'll hook you up. great guy and VERY helpful! and he's a panoz lover to boot!
Old 07-22-2010, 02:21 PM
Also, i have a pro-form 750(based on holley 4150) i'll let go CHEAP :-D
Old 07-22-2010, 03:13 PM
panozracing's Avatar
panozracing panozracing is offline
I have a mighty demon 650 that you can buy as well. On our engine it produced 600FWHP.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
