Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-19-2010, 10:42 PM
kawyboy kawyboy is offline
Question Dodge Ram 1500 A/C Leak HELP!
Hello all and thanks in advance. I have a 2001 Dodge Ram 1500 quad cab.
318 Motor about 130,000 miles. A/C went out. I had it recharged with dye a couple times from a dealer buddy of mine but he can't find a leak anywhere under the hood. Says it has to be inside.
What are my options? Has anyone seen this? Is this comon on Dodge pickups?
If I recharge system A/c Gets cold works fine.
It only takes a couple of hours before it leaks down and is warm, warm, warm.
Any and all input welcome. My wife has Asma and I need to get it fixed ASAP and for as little $$$ as possible.
Old 07-20-2010, 06:43 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Dodge Ram 1500 A/C Leak HELP!
The evaporator may be leaky.
Here's a pdf of a 2001 factory service manual. It loads/saves kinda slow but it's all there and I haven't had any problem with it.
http://pdftown.com/Dodge-Ram-2001-Service-Manual.html
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 07-22-2010, 02:40 AM
hundahunta hundahunta is offline
sounds like an evap, should be a pretty easy fix since you friend has automotive experience, takes about 2 hrs...
Old 07-22-2010, 07:19 AM
brcidd's Avatar
brcidd brcidd is offline
Definitely evaporator leak-- Dodges are known for this-- good to know that the dash pull can be done in 2 hours-- book time is over 6 hours.....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 07-22-2010, 10:31 PM
AF - Advisor
If flatrate shows 6 hours, it'll take me 3 days
