Old 07-19-2010, 12:14 PM
randyfromrichmond randyfromrichmond is offline
Replaced fuel pump- now won't start
Replaced the fuel pump and filter on 2001 Jimmy. It ran just find that day- then the next morning will not start. Sounds like normal- battery/starter seem fine. Any ideas?
Old 07-19-2010, 01:23 PM
Westell Westell is offline
Re: Replaced fuel pump- now won't start
Can you hear it prime on key on if not check all the plugs to make sure there tight. Give it a jump start if that works may have a dead cell in the battery.
Old 07-19-2010, 06:59 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
ave you checked fuse?
If you can hear fuel pump run or jumper it and get it to run give us the fuel pressure readings.
MT
