Old 07-18-2010, 09:41 PM
buffercat buffercat is offline
2002 lesabre blowing hot air on drivers side
My Lesabre's AC is blowing 20 degrees warmer on the drivers side than the passenger. Passenger is cold and where it should be temperature wise, whats causing the issuse with the drivers. Thanks
Old 07-19-2010, 12:03 PM
nomechanicatall nomechanicatall is offline
Re: 2002 lesabre blowing hot air on drivers side
Mine was doing about the same thing a couple of years ago and I added some 34 freon to it and has worked great ever since. That would be the first thing I would check if I were you. Don't know why it blew out cold and warm if the freon is low , but that cured my situation definitely. I have a 2000 lesabre and like I say haven't had nothing but very cold air since.
Old 07-19-2010, 12:39 PM
brcidd's Avatar
brcidd brcidd is offline
A sure sign of a low refrigerant charge- find and fix leak , evac and recharge to factory spec- and all will be fine....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 07-21-2010, 05:58 AM
chubcobear's Avatar
chubcobear chubcobear is offline
Climate control actuator located behind glove box. Gears inside crack. Do you hear creaky noises when you adjust temp?
Old 07-21-2010, 06:23 AM
I should be getting it checked today to see if its low,will post results. Chubcobear, no creaky noise all is quiet when changing temps.
Old 07-21-2010, 07:00 PM
yes it was low thanks for the help and it even blows cold air to the rear of the car again
