Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 07-18-2010, 09:09 PM
cjsuds13 cjsuds13 is offline
high idle
replaced tp sensor was good for a few months,started happening again.checked connector that runs through floor,looks ok.The wires at the tps were pinched under air cleaner tube,repaired by soldering and shrink tubing.Could the iac be causing this problem.Had van running,disconected iac,nothing happened,idle stayed normal.Disconected what i beleave is the evap purge solinoidjust behind iac and the idle went high.Could evap cause high idle.
Old 07-18-2010, 10:51 PM
lesterl's Avatar
lesterl lesterl is offline
Re: high idle
Vacume leak could cause high idle, check your lines over good, and post what year your rig is.
NVM, 2003, Why did you start a new thread for this since you asked about it on your old one?
1997 Chevrolet Venture SFI 3.4l Auto 249k
2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k
http://www.s10forum.com/forum/attach...nsor-chart.gif
