Old 07-18-2010, 08:30 PM
TDWPgtp's Avatar
TDWPgtp TDWPgtp is offline
oil mixup =(
so i managed to purchase and put in 2 quarts of the right oil (10w30) and 2 quarts of the wrong oil (5w20). now i dont feel like changing it all and buying new oil again so i was wondering if this mix is ok to drive with. does it actually make that big of a difference or will i be ok until the next oil change comes around? thanks in advance
Old 07-18-2010, 08:33 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: oil mixup =(
5w20 is pretty thin stuff.
But 2 plus 2 doesn't add up. Oil capacity on a 3800 after a filter change is 4.5 quarts. Do you have the right amount in there?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 07-18-2010, 08:51 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: oil mixup =(
From what I have read, a mix of otherwise-compatible oils will result in a weight that is approximately proportional, in this case, about 7.5 W 30.
IMO if you really care about the car, drain it and put the right stuff in. If you drain into a clean container, the old oil can be reused in stuff that is not so important, like lawnmowers etc.
If this were wintertime, I would say just leave the thin stuff in there, but in summer the extra viscosity is useful.
Old 07-19-2010, 07:35 AM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: oil mixup =(
shouldnt it be 7.5w25?
if it were me, i MIGHT let it stay in if it was winter. right now though, not a chance. im not saying it will hurt anything, but oils cheap, i personally would just sleep better at night
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 07-19-2010, 01:56 PM
TDWPgtp's Avatar
Re: oil mixup =(
oo wow. at some point, a mechanic wrote 4.0 quarts near the oil cap, so i assumed thats what it took. ill make sure to put in 4.5 though. and i guess ill change it all again since everyone seems to have the same opinion.
i wasnt sure because the guys in the machine shop at my dads work said that it shouldnt really make a difference over such a short change interval.
Old 07-19-2010, 07:47 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: oil mixup =(
There is no problem mixing the two different multi-viscosity oils stated. The alternate oil for a Series II 3800 engine is 5W-30 so the 5W-20 is close enough. You are not supposed to use oil like 20W-50.
GM has gone to 5W-30 in just about all their V6 and V8 engines now.
Also, gentlemen the oil capacity is and always has been 4.5 quarts with filter change as Tim stated.
Timeslip 08/12/06
AF Community Guidelines
