Old 07-18-2010, 07:17 PM
Urambo Tauro Urambo Tauro is offline
2003 6.6 Duramax- Turbo Issue?
2003 Chevy C3 Stake Truck- 233,000 miles
LB7 Duramax engine
Hello all, the truck in question is a work truck, not mine, so I have occasional access to it. I have no experience with turbos, much less turbodiesels, but here's the thing--
When driving, around 2,000 revs and higher, I hear a "rushing air" sound that rises and falls with engine revs. I'm sure this is the turbo, but I don't feel any extra power kicking in, not even after lag-time. It feels (and sounds) like all the turbined air is escaping, wasted.
The truck and engine otherwise seem fine (although I am told it has an injector issue that is not getting fixed anytime soon).
What do you think?
1995 Ford Mustang GT
1994 Mercury Cougar XR7
Old 07-18-2010, 07:55 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: 2003 6.6 Duramax- Turbo Issue?
Is this sound new, or has it always been there?
It may be a plugged exhaust, or a bad turbo bearing.
MagicRat's Avatar
Old 07-19-2010, 05:09 AM
I have only been driving this truck for less than a month. The guy who normally drove it (past ~3 years) assumed the current sound and power was normal. Whatever went wrong probably happened before he started driving it, because another co-worker clearly remembers the turbo "kicking in" could be felt while driving.
Old 07-20-2010, 11:13 PM
kahjdh's Avatar
kahjdh kahjdh is offline
I know on the variable vane turbos the impellers carbon up and sieze so you have to take the turbo apart and clean it up. Im not sure when they started putting them in but I would check for that. Also if it is not a variable vane check to see if the waste gate is binding.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 07-24-2010, 08:40 PM
I think they started the variable vanes in 2004, with the LLY engine. Where is the wastegate, what does it look like, and how do I check it?
Old 08-01-2010, 09:28 PM
On top of the engine, passenger side, I see some kind of diaphragm with a rod sticking out, which connects to a lever in the engine.
Is this the wastegate? ...the diaphragm, or whatever the linkage moves inside the engine?
I asked a coworker to rev the engine in park while I watched, but the linkage never moved at all- was it supposed to?
Old 08-16-2010, 09:48 PM
Anybody?
Old 08-17-2010, 08:34 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
LB7 Duramax engine
What do you think?
If it has a injector problem you will need to fix that first thing.
The turbo will not work right if engine is not running right.
Does it have any stored codes or check engine lights?
What is the injector problem?
MT
Old 08-22-2010, 06:22 PM
I will try to get that information.
From what I've gathered so far, the injector issue seems to be a common problem, probably the injector recall issued to LB7's. However, I'm afraid this truck is past warranty, and a ($2-4K?) fix just isn't going to happen very soon.
The check engine light IS on. Maybe I'll get a chance to run to an Autozone or something and get the codes- or can I pull them with a paperclip jumper?
Old 08-23-2010, 08:09 AM
MT-2500's Avatar
AF - Advisor
Auto zone may be able to get OBD11 codes but a engine capable scanner is the best way to check it out.
Any check engine lights on?
Post back any codes you get.
MT
Old 09-21-2010, 01:12 PM
I had to take the truck home last night, so I took the opportunity to run over to Autozone and pull codes.
One code came up, p0802. It has something to do with the transmission; I don't think it's related.
Old 09-21-2010, 05:35 PM
MT-2500's Avatar
AF - Advisor
OBD11 code?
What transmission and which truck ?
MT
Old 09-22-2010, 08:18 PM
The code was pulled from the port under the dash on the driverside.
I'm not sure what transmission it has exactly; it's an automatic for sure. The truck is a 2003 Silverado 3500 stake truck, 6.6L LB7 Duramax diesel.
Old 09-23-2010, 08:29 AM
MT-2500's Avatar
AF - Advisor
Code 802 is a transmission electrical control problem.
But that AZ obd11 code read out does not do much as far a testing or checking out your problem.
It needs to be put on a engine transmission capable scanner to get transmission and engine running problems.
Which can check out injector and turbo operation.
You can not tell much by just looking at wast gate rod/lever.
What was the info/history on the injector problem in first post?
MT
