Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 07-18-2010, 05:02 PM
jnslick's Avatar
jnslick jnslick is offline
exhaust help
i'm turning my 95 DOHC into a flat track racer, and i'm not sure what if any damage i would be doing to it if i shot the exhaust manifold through the hood, seeing as how i would be getting rid of the O2 sensors and cats, i know in a previous car i owned which was a 1.6 I4, simply cutting the exhaust so short decreased the backpressure enough to blow out the valves, so my question is, will i blow my engine if i run the exhaust through the hood??? also, i'm putting an aftermarket steering wheel in it, but not sure if i'll need to buy an adapter or if i can modify the brackets thats on it now and slip it on there, so any help would be great, thanks
Old 07-19-2010, 09:43 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: exhaust help
If you're getting rid of the HO2 sensors, you need to go carbed...
These engines shouldn't blow from a lack of back pressure. You will lose low end torque. You can compensate, of course, with a high stall converter and a steep differential (3.73s or 4.10s).
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 07-19-2010, 10:48 PM
jnslick's Avatar
Re: exhaust help
...they actualy make a carb intake for a 4.6? wow, thats news to me haha...prolly doesn't help i've always been Chevy fan tho
Old 07-19-2010, 11:21 PM
Re: exhaust help
You'd have to get a manifold that could support the carb and delete the injectors.
Edelbrock makes one. They offer it in both EFI and carb versions. I've only seen one panther owner use one and it's on an EFI setup with nitrous and a handful of other mods.
http://www.edelbrock.com/media/news/...ve/091407.html
I also don't know what kind of tuning it would take since the transmission is electronically controlled. Unless you want to swap in a 5-speed manual too, which has been done very successfully before.
Old 07-20-2010, 09:25 AM
Re: exhaust help
Looking back at this, did you really swap in a DOHC 4.6L? If you did, you probably don't have room for headers, but if you have the SOHC 4.6 still, long tube headers are now available for our cars (92-02 model years) which can gain some power if you aren't hellbent on the exhaust going through the hood. They will also allow you to keep the EFI.
Old 08-01-2010, 12:44 AM
jnslick's Avatar
Re: exhaust help
actualy, the car came with the DOHC, i don't have it anymore tho, makes me realy sad, had to sell it, damn economy, but yeah, before i sold it for a derby car, i took it up my hillside so at least i had a little fun with it
