Go Back   Automotive Forums Car Chat > Cars/Parts for Sale/Exchange > Parts for Sale
Old 07-18-2010, 10:37 AM
53sled 53sled is offline
455 oldsmobile complete 375 horse
plus lots of extras
$1500 in kansas city
this same build produced MORE power than the 375 horse toronado (stock) motor from 1970. going with a less street friendly cam can net 420 horse, but then you need a loose converter and better ignition. this is a solid motor to get around town with. only 25 pounds heavier than a cast iron intake equipped small chevy. this engine doesn't have to work as hard to get the power. will last a long time.
this engine comes with
torker intake 780 cfm qjet hei distributor stock exhaust manifolds
l2323 pistons arp rod bolts, rods were resized properly
victor head gaskets for a true 9.5:1 motor
th400 with driveshaft
balanced and blueprinted. new not broken in
over $2000 invested
all you need to put in a midsize gm to go cruising
another spare parts motor included
Old 07-18-2010, 10:39 AM
Re: 455 oldsmobile complete 375 horse
email me david.fruits at gmail.com or call 913- six three six - 777 nine
$535
pistons
$287
intake
longblock, bored .030, forged L2323 pistons, balanced, blueprinted. arp rod bolts. stock oil pan. have receipts. .460"/268* cam mild street grind edelbrock torker intake, hei distributor. should be 375 hp 400 ft lb on pump gas. A bigger cam with this setup could produce as much as 420 horse with tuning. And with earlier heads it would make even more power. These are not aftermarket heads, this is with good ol detroit iron.
PROOF!
*also have stock intake that some classes require, chrome valve covers, hei distributor, exhaust manifolds, and th400 turbo 400 car transmission with slip yoke and drivesahft. second set of F heads with low miles on rebuild, spare block/crank that need attention, second oil pan, 780 cfm q-jet, aircleaner, fuel pump
email me for more info. prefer pickup.
Tags
big , block , power , torque
