Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 07-17-2010, 04:26 PM
hadit hadit is offline
from a new member HADIT
ok i have a 1991 trooper we just rebuild the engine from bottom up rings timing chain the works you may say, just put engine back in replug all wiring connection back , went over everything before reconnecting battery an now car will not start, from what i can see not getting any fire from ignition coil i tested all wires around coil with test lite all showing ok, replaced rotor, dis module, dis cap, ign coil, check all grounds clean them, check fuel to tbi unit its getting fuel, just no run, we do have a car alarm in the car that was installed wind we got the car new in 91, i am out of luck on this one if any had this problem b4 maybe you help yours truly hadit
