Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-16-2010, 06:32 PM
bluemounddog bluemounddog is offline
a/c vents
when car is under power. a/c changes from middle vents to defroster.
cruise was not working checked and repaired vacum hose under battery box.
this fixed the cruise, but still have the vent problems. anyone have any ideas? thanks.
Old 07-16-2010, 10:17 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: a/c vents
There's still a lack of vacuum, either more leaks or the vacuum source/pump is getting weak...
Is that a diesel?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 07-19-2010, 10:24 PM
kawyboy kawyboy is offline
Re: a/c vents
Passenger side of motor, along the intake, there is a on way check valve in the vacum line. If you can see through it replace it. That solved my problem.
I have no curise also. What line under battery box did you find cracked?
Old 07-20-2010, 08:30 AM
Re: a/c vents
I replaced the line going to the the speed control servo. battery acid
had eaten through the line. it's located under the battery box the line
connects on the back side of servo. hope this helps.
