Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 07-15-2010, 11:31 PM
orange57 orange57 is offline
AC Blower Motor Always on
Hey guys,
I have an 89 Old 98, it has the electronic control unit in the dash. Anyways, the blower motor always remains on, even when the key is off. I had to disconnect the power connector from the motor wo it wouldn't kill my battery. Is this going to be a short up underneath the dash that i'm going to dig out? Or would this be indictive of the control module not working properly? Any thought?
Thanks,
matt
1989 Oldsmobile Ninety-Eight
2002 Volkswagen Jetta GLX VR6
Old 07-30-2010, 12:21 AM
Re: AC Blower Motor Always on
Ok, so tonight i was messing with the car, i plugged in the blower motor, via the two wire plug on teh back. After it had been running for a while, and I was finishing up I went to unplug the connector and the whole connector and wires were very hot. Is this normal? It doesnt seem like it should be. It seems like it may be melting the plastic on the insulation. What could this a symptom of?
Thanks,
matt
Old 07-30-2010, 11:45 AM
maxwedge maxwedge is offline
A990 racer
You need a new blower power module, should be r/s of cowl under the hood, atop the evap case.
Old 07-30-2010, 08:10 PM
I'm assuming that is the unit that the wires from the blower motor feed into. Is this a junkyard item? I don't think I saw anything like that on any of the car parts websites.
Thanks,
matt
Old 07-31-2010, 07:31 AM
A990 racer
Should be available from Napa, maybe you/ or they are using the wrong terminology
Old 08-01-2010, 07:46 PM
Max,
I assume this is the module you are talking about. Is there a way to disconnect it from underneath the hood. I stared at it and tried to remove/disassemble with no luck. Is there a trick to removing this that I don't know?
Thanks,
matt
Old 08-01-2010, 09:16 PM
brcidd's Avatar
brcidd brcidd is offline
if (Since) you have automatic climate control- you need the blower motor module--it is in the HVAC case on top- follow the blower motor wires back to it.
It is not in your photo- that is the power connector that goes inside the car-- forget it
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 08-01-2010, 10:49 PM
I belive I found what you were refering to, it is the panel mounted right below the red box in the picture.
As far as folowing the wires back, when I follow them back the go to the power block at the side, unless inside the plastic casing the double back and I don't notice that. What does the module in the first picture do?
Thanks for the help.
matt
Old 08-02-2010, 07:18 AM
brcidd's Avatar
yep you found it...
The first photo is an electrical connector- has all the engine harnesses in it- plugs into the car when engine is installed- has a bolt in center to hold it in place-- you remove it only when you pull and engine out......
'99 GMC Yukon
