Go Back   Automotive Forums .com Car Chat > Jeep > Cherokee
Old 07-15-2010, 09:39 PM   #1
javatrooper
javatrooper's Avatar
horn relay location 93 sport?
Horn itself works if hot wired. Ground switch in steering wheel works. So where is the damn horn relay and which fuse controls the horn. I have a shop manual for a 93 grand cherokee and it is totally different than my sport. Does that make any sense? Please help, I'm stumped.
javatrooper is offline   Reply With Quote
Old 07-15-2010, 10:10 PM   #2
javatrooper
Re: horn relay location 93 sport?
Okay, think it fuse #11, it's fine. Think I found relay center under instrument panel to right of steering column. The problem is that I only have 2 relays there and lots of empty slots. I just picked this car up so don't know if it's missing relays. Can someone describe the exact slot that the horn relay plugs into? Thanks
Old 07-16-2010, 06:10 AM   #3
fredjacksonsan
Caution: Monkeys bite!
fredjacksonsan's Avatar
Send a message via AIM to fredjacksonsan
Sometimes not all slots are used on relays since they have multiple applications (car manufacturers use the same part in several vehicles sometimes, especially small electrical parts).
What you might try is to go to the auto parts store with the relay you found, and request the part that you're trying to replace...if they match you're in business.
I know I didn't answer your question directly, but I'm not one of the under dash guys.... hopefully they'll be along shortly.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
fredjacksonsan is offline   Reply With Quote
Old 07-16-2010, 01:57 PM   #4
javatrooper
Thanks for the input fredjacksonsan.
Here's how I figured it out for those in a similar situation. I pulled the entire relay panel free, and then opened up the back. I could immediately see that there was a missing relay. Then I looked at the wire running to the horn and saw it was green/red stripe.
Sure enough the missing relay had the green/red wire. Plugged in a rely and "horn". Before I pulled the back of the panel off, I thought there were only 2 relays wired. So make sure to snap it open to get a good view.
Aloha.
