Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 07-15-2010, 06:52 PM
divemaster divemaster is offline
Question HELP! 2000 E350 SD Van AC stumper...
Hi there,
I have a 2000 E350 Super Duty van and the AC compressor will not come on. I have power on both sides of the pressure switch but still the clutch will not engage. Any suggestions??
Thanks in advance,
Shane
Old 07-18-2010, 11:50 AM
Davescort97 Davescort97 is offline
Escort guy
Re: HELP! 2000 E350 SD Van AC stumper...
If you are getting power to both sides of the low pressure switch that narrows it down quite a bit. There is only the A/C relay and the clutch on the compressor after that .
Bypass the relay and see if the clutch comes on. Or you could run a hot wire from the bat to the terminal on the compressor to see if it works.
Old 07-18-2010, 05:25 PM
Thanks for the advice, I will try that. Any idea where the relay is located? It is not in the owners manual...
Old 07-19-2010, 06:35 PM
there is no power to the ac clutch with the engine running and the ac on high.... I can't seem to find a relay or a schematic.....
