Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 07-15-2010, 06:26 PM
82olds98 82olds98 is offline
82' olds 98 obd1 code 21 help
I have an 82' olds 98 coming home today check engine light come on. so i get home probe the A and B terminal and i come up with code # 21. i looked up the code says Throttle Position Sensor High Voltage. It has the 4 barrel carb so im not sure where to look exactly. And when i find where to look how do i test what is the problem? Thanks
Old 07-15-2010, 07:15 PM
maxwedge maxwedge is offline
A990 racer
Re: 82' olds 98 obd1 code 21 help
The tps is in the carb, make sure the connector is ok, then replace it, for a picture of it try autozone.com, repair guides.
