Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 07-15-2010, 01:07 PM
KrEEsToN KrEEsToN is offline
97 SL2 Not getting power
Well basically every once in a while like every couple weeks or so the car wont get any power to the dome light, radio, chimes and fuel pump. i turn the key and i hear a click but no other sound. everything else gets power except those few things and of course the car wont start. its not the starter or battery. and after letting the car sit for a while, it could be a hour to a couple days and then it starts up just fine and runs fine for a couple few weeks til it happens again... what should i be looking at??
Old 07-15-2010, 04:47 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Re: 97 SL2 Not getting power
Without knowing anything else, I'm thinking it is most likely a bad ignition switch. If you do find a blown fuse try replacing it and see what happens first before replacing the ignition switch. You could have a short elsewhere, but the ignition switch commonly shorts out when they fail in these cars. This is a common issue with the S-Series.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Old 07-15-2010, 09:06 PM
k i checked some fuses and the one for the horn was blown i put another one in and it blew it right away so a short then? but would that have to do with everything else?
Old 07-15-2010, 11:32 PM
Ruley73's Avatar
Yes, sounds like you have a short in the horn circuit. Chances are it is isolated to that circuit and not anything else so it is a separate issue.
My rides:
- Steve Smith (Red)
