| Search | Car Forums | Gallery | Articles | Helper | Air Dried Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
A/C Compressor Replacement
Getting ready to replace the a/c compressor in a 1997 Lumina with a 3.1L. How much oil should be added to the sump of the compressor (GM V-5) when I install it? All I can find are system capacities.
Thanks! |
#2 | |
Re: A/C Compressor Replacement
3 ounces in the crankcase...so what is wrong shaft seal leak and comopressor belly o-ring leaks?- both of which are resealable
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
#3 | |
Belly orings are leaking on it. I debated resealing but it is so corroded up I elected to just change it. Any other pointers to offer as I switch it out?
#4 | |
2nd on the ~3oz. in the crank.
I would suggest draining it into a measuring cup or graduated cylinder to make sure you are putting in about the same amount which came out, so as not to overfill. If only 1oz. or so comes out, then you should still be OK adding about 3oz. in case the oil was low in the first place. Some manuals suggests pouring the oil into the intake side of the compressor, but I have not had much luck with this. Seems to only hold about 1oz before it starts coming out. Then it really comes out when the compressor is turned into position when bolting it back on and just makes a mess. Also pour out and measure the oil from the old dryer and follow the same rule. Seemed to work OK for me so far....AC has been blowing cold since April here in TX.
1995 Lumina LS Sedan 3.1L - 215K mi - Daily Driver 2002 Accord EX Sedan V-6 - 209K mi - Wife's Daily Driver 2000 Silverado LS RCSB 5.3L - 168K mi |
