Old 07-14-2010, 06:43 PM
Godofwarmike's Avatar
Godofwarmike Godofwarmike is offline
Question 1998 F150 Airbag light code 44
Just recently picked up a 1998 F150 4.6L 2wd fairly cheap and the airbag light is on. Its blinking 4 - 4 (code 44) which i believe to be RH crash sensor not mounted correctly.
I checked the connections and they look good. I unbolted it and cleaned the surface it goes on plus the tabs coming off the sensor and rebolted it back up and it still isnt making the light go out.
Is there any way to check the sensor itself?
Or any other ideas of what the problem could be?
1999 Purple Plymouth Neon SOHC Automatic
Bought Feb 2009 For $700
125,000 miles
Maybe the world record for car with most hidden zip ties
Old 07-18-2010, 01:00 PM
big white bufflo big white bufflo is offline
Re: 1998 F150 Airbag light code 44
the box is located on the pass side kick panel next to glove box some can be resetit may need to be or just replace it
