Old 07-14-2010, 11:00 AM
cumax57 cumax57 is offline
Hot camaro
90 RS CAMARO wit smalll 307 v8 installed comp cam magnum 280h in car. car
runs at 220 degrees after 10 mile trip in hot weather tried timing new radiator
new water pump non restrictive XHAUST system,new stock coolpng fan and motor . Where else should i look???????? Tried new after market adjustable fan control system , still running too hot. IS air dam really an important factor for cooling??
Old 07-14-2010, 11:48 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Hot camaro
If you're running the stock electric cooling system, the fan isn't signaled to come on until 225-230. You can buy an adjustable fan switch and lower the on temp.
Old 07-14-2010, 06:49 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: Hot camaro
Is the black plastic air dam still in tact or possible missing from underneath the car, I agree with wright, get a lower temp fan switch, most guys run a 180.
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 07-15-2010, 07:45 AM
wrightz28's Avatar
Re: Hot camaro
And a lower temp stat
Old 10-12-2010, 07:42 AM
Post Re: Hot camaro
[quote=cumax57;6720017]90 RS CAMARO wit smalll 307 v8 installed comp cam magnum 280h in car. car
Old 10-12-2010, 07:44 AM
Re: Hot camaro
Old 10-13-2010, 07:47 AM
wrightz28's Avatar
Re: Hot camaro
VERY
Old 03-16-2011, 12:02 AM
FastIROCZ28's Avatar
FastIROCZ28 FastIROCZ28 is offline
IraqIROCvet03
Re: Hot camaro
Our cars run hot from the factory, so 220 to 235 is about normal in city stop and go traffic. I upgraded all of my cooling parts last year on my IROC and my fans worked after that along with the fact that my car has never overheated since. It used to overheat alot before that.
But I run a 195F t-stat which is the factory temperature for my car and I normally run at between 200F and 220F without worries. If your fans are cutting on then your car won't overheat and you have nothing to worry about. Even in high performance use my car runs pretty cool with my cooling parts but having all of that heat build up underneath the hood with nowhere to really go (since heat rises up) does hurt performance. Get a cowl hood for extra cooling power if you'd like.
1988 IROC-Z28 Camaro 350 TPI Modified.
Stage 2 IROC in order; mildly built A4 Trans.
Highest speed - 150mph @ 5,600RPM's.
1/4 mile time in 03/09 before I began project on car was 14.0 @ 98mph @ Gateway International.
Best 0-60 was 4.9 seconds as of 01/2011.
Highest ticket so far: 75mph in a 45mph zone.
Best kill so far: LT1 Camaro Z28 in 02/2011.
