Go Back   Automotive Forums .com Car Chat > Oldsmobile > Bravada
Old 07-14-2010, 10:08 AM   #1
ragincagun88
98 bravada won't start, not sure if fuel pump is problem.
My 98 Bravada, until this morning, was having a hard time starting first thing in the morning. Would turn key on and off 2-3 times, could hear fuel pump, and finally start, but would sputter and run rough for a couple of minutes, then run good rest of day. But this morning go to start and now can't even hear the fuel pump and engine is not even attempting to start. The motor is a 4.3 if that matters, have not checked fuel pressure yet either. Have checked other threads but didn't see anything on this particular problem. Any help would be appreciated.
ragincagun88 is offline   Reply With Quote
Old 07-14-2010, 10:16 AM   #2
jdl
Re: 98 bravada won't start, not sure if fuel pump is problem.
Fuel pressure is the first thing I would check. If you have the spider fuel system, it is noted for problems.
jdl is offline   Reply With Quote
Old 07-14-2010, 10:32 AM   #3
ragincagun88
Spider fuel system? Please elaborate.
Old 07-14-2010, 04:30 PM   #4
jdl
They call it a spider fuel system because of the legs coming off the injectors.
Old 07-14-2010, 10:57 PM   #5
ericn1300
AF Premium User
ericn1300's Avatar
Follow this previous post http://www.automotiveforums.com/vbul....php?t=1018941 and check the fuel pressure first.
ericn1300 is offline   Reply With Quote
Old 07-15-2010, 12:20 AM   #6
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Like Eric says and here's where you check the pressure,
Chris Stewart is offline   Reply With Quote
Old 12-09-2013, 09:33 AM   #7
sdrosos
I had that same problem when I first bought my bravada, but it ended up being a short that drained the battery.
sdrosos is offline   Reply With Quote
Old 12-09-2013, 09:34 AM   #8
sdrosos
I had that same problem when I first bought my bravada, but it ended up being a short that drained the battery. See if the battery is good.
Old 12-09-2013, 10:12 PM   #9
Chris Stewart
AF - Advisor
Thanks for sharing sdrosos!
Old 08-14-2015, 06:21 AM   #10
beir
old dog learnin new trick
beir's Avatar
I know this reply is late but a quick way to check for fuel pressure is to push on shader valve on fuel rail..if nothing comes out u have no pressure..not a accurate check but will point u in right direction.
beir is offline   Reply With Quote
The Following User Says Thank You to beir For This Useful Post:
Chris Stewart (08-14-2015)
Old 08-27-2015, 08:32 PM   #11
ericn1300
AF Premium User
ericn1300's Avatar
This test is only valid if you have no fuel when you press on the valve. You need 60 pounds of fuel pressure so don't be fooled by a weak stream when you push on the shrader valve, you will still need to test it.
Hey Chris, do you think one of those 99 cent tire pressure gauges could be used to check the fuel pressure on a shrader valve? I'll have to try that someday. By the way I got Sylvester to pass the emissions test and back on the road for under $50.
The Following User Says Thank You to ericn1300 For This Useful Post:
Chris Stewart (08-28-2015)
Old 08-27-2015, 09:21 PM   #12
liya_leacree
Just hope you can find out the reason quickly. Good luck.
liya_leacree is offline   Reply With Quote
Old 08-28-2015, 06:52 PM   #13
Chris Stewart
AF - Advisor
The tire valve stem is smaller than a schrader valve.
Harbor Freight has that test pressure kit on sale for around $20 every now and then.
Good on Sylvester, what was wrong?
Old 08-28-2015, 11:04 PM   #14
ericn1300
AF Premium User
ericn1300's Avatar
Did a smoke test and about every hose was leaking. One under the egr valve was completely missing. To many air leaks drove the hydrocarbon count way up. I guess it was to be expected, all the rubber is over 23 years old now.
Old 08-29-2015, 09:37 PM   #15
Chris Stewart
AF - Advisor
Thanks, I'll start checking hoses.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
