Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-13-2010, 11:13 PM   #1
fanofwallace
Unhappy 93 Mustang need help
I have a 93 Mustang that is not charging properly. I have had the battery tested and charged. I have replaced the alternator. When I replaced the alternator I tested the battery with a volt meter and it was at 12.6. When I start the car the volts drop down below 9.0. Can anyone give me any other options to check.
fanofwallace is offline   Reply With Quote
Old 07-13-2010, 11:17 PM   #2
Blue)(Fusion
Blue)(Fusion's Avatar
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 93 Mustang need help
At idle, the voltage should increase to above 13V to keep the battery charged. I'd look for a grounding issue.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Blue)(Fusion is offline   Reply With Quote
Old 07-13-2010, 11:21 PM   #3
fanofwallace
Thanks is that a ground for the battery or alternator.
