Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-13-2010, 09:49 AM
Nego's Avatar
Nego Nego is offline
Angry another overheating eclipse.....
my eclipse that i had for a couple of years has had overheating problems forever
relplaced:
radiator
radiator cap
thermostat
ac cooling fan
water pump
most hoses
the cooland in the reservouir would dissappear full in less than a week so i started using water and the temp. gauge would get like a quarter away from overheating especially when the car was stopped i.e. for a red light. so from midway to a quarter away from overheating all the time but never overheat so i didnt care cuz of so much money i spent on it, so for me as long as it worked i was ok.
so now its over heating the gauge its staying preety high so when i got home yesterday i left it on to see if it would overheat and sure it did i dont get it i really ran out of answers to fix the dang car. anyone has any ideas? i really want to know why the coolant is dissappearing like that cuz is not leaking or anything unless its doing it while im driving but i chked and everything looked normal!?
Old 07-13-2010, 09:52 AM
ned032002's Avatar
ned032002 ned032002 is offline
Re: another overheating eclipse.....
The coolant is going somewhere. Have you checked your oil for coolant? Have you had any milky brown stuff in your coolant? Is she smoking at all?
Old 07-20-2010, 06:56 AM
Nego's Avatar
yes i did all that and nothing...
Old 07-20-2010, 10:01 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Are both of your fans coming on? I tried to run only 1 fan for 2 years and always had overheating issues. Make sure both fans are coming on. I would even wire the condensor fan to come on with the rad fan to help cool it down. This can be down by just jumping the relay in the fuse box.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 07-20-2010, 10:01 PM
SLoe's Avatar
SLoe SLoe is offline
You say you replaced most hoses, but not all? You should pressure test your system, you may have a pin-hole somewhere. It's hard to see them most of the time, and just because you don't see a big drip doesn't mean it's not leaking. Read this.http://www.automotiveforums.com/vbul...d.php?t=587560 Read it.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 07-22-2010, 09:56 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
+1 on the fans. Make sure they are blowing the right way as well.
Kris
2012 Genesis Coupe 2.0t
Old 07-25-2010, 10:14 PM
cantgo2fast's Avatar
cantgo2fast cantgo2fast is offline
I have the opposite problem mine is fine around town and at stop lights but on the highway it overheats but only when I go up a sustained hill. It'll be fine for the longest time then a long incline will come up and temps will just keep rising. Fans are coming on. I haven't checked the oil and most of my hoses are also new
1995 GSX 2Gb bumper
Evo3 16g @18psi/walbro190/Greddy type S Bov/Dejon Intake/Bushur 3in DP/Custom 3in catback exhaust/FIC 750s/innovateLC1 WBO2/DSMLINK v2.5/Axxis ultimate pads/Aeromotive AFPR/ETS FMIC/Tein SS coilovers/ACT 2600/6puck/ACT flywheel/
Enkei RPF1 (15.6lbs) with 245/17 Dunlop Star Specs
Wish list:
CAMS
Old 09-08-2010, 09:08 AM
Papa George Papa George is offline
I do not know if you got this fixed yet if so please post your findings.
we had this same issue with my wifes truck (not the eclipse) but still could be the same issue.
On long trips the truck would over heat all coolant gone!
what we found was a bad head gasket. when the truck was running one of the cylinders was causing pressure in the cooling system and the coolant was sent out the overflow.
you can check this by filling the colling system and running the car wile watching your hoses you will see pressure build up in the hoses. (extreme pressure)
you can also do a leak test on the cylinders if you have an air compressor and this would tell you what cylinder is bad (not an issue with a 4 cylinder) only one head gasket. this is the safest way to check the head gasket.
