Old 07-12-2010, 08:07 PM
joehinvt joehinvt is offline
Exclamation absolutely no electricals
my buddy has a 89 camaro ls 5.0. he pulled outta his driveway and drove 2 ft and it just died. he calls me and i go to jump it and he says nope,its got nothing! no bells,no door chime,no interior lights ,nothing. its got plenty of juice according to my dvm. but ALL electrics are dead. so where do i start? im not a moron i know my way around a car. just wanna fast track to maybe trouble shoot this and save me some time! i really appreciate all replys!!!!!!!!!! joe h
Old 07-13-2010, 01:39 AM
chvyl01 chvyl01 is offline
Re: absolutely no electricals
Are you serious? turn the headlights on....do they come on?...if yes turn the key....observe what the headlights do. if the headlights do not come on check the following....cable from battery to the starter...could be loose broken burned or shorted...ensure its not against the exhaust...if this cable is ok remove the starter have it tested...the solenoid could be bad...check wire from alt to the battery...check the power wire from the starter to the ignition <.....this one could be the culprit. no power usually means the wire from the starter to the ignition..or solenoid...purple wire. Good luck....
Old 07-13-2010, 07:01 AM
when i said no electricals i meant NONE! no headlights or anything. i am gonna check your other suggestions tonite so thanks for those!!......joe
Old 07-14-2010, 06:47 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
There is no need for comments like that, although you are correct, for no power to anything i would check the battery cables, 3rd gen camaros have 3 power feeds coming off the main post on the starter. 2 go to the fuse box, and the other goes to the small junction block beside the battery, loose 1, your going to lose some acc's but not all, and the purple wire(solenoid) would only cause a no start.
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
