Old 07-12-2010, 01:33 PM
d.weglarz13 d.weglarz13 is offline
Revving real high, and stalling!!! help!!
Hey guys. I have a general problem, that im hoping someone can shed some light on. my 94 Saturn 4 door sedan just started doing some weird stuff. It starts to rev really high if i put it into neutral or drive, and sometimes it will go down and stall. But, mostly just revving high, even when in Drive, it still revs higher than usual, pushing my car off faster without even touching the gas. Also, at the same time, sometimes the temperature gauge in the car will fly all over the place, or get stuck in the cold position, even when the car is hot, and then it will work fine again, and so on. What could this be? It even over heats sometimes lately, but im putting a new thermostat in today, so hopefully that should do it? I am not a mechanic, and do not have the skill to test wires with weird gadgets, etc. I know the basics, though, and if its mechanical, i can fix it. Just please, someone give me an idea on what to do first....Idle Control Valve, Throttle position sensor? i just don't know what it could be, but again, im not a mechanic. Please help
Dave
Old 07-12-2010, 02:54 PM
jdl jdl is offline
Re: Revving real high, and stalling!!! help!!
Check for applicable trouble codes. You should be able to check mil codes? engine idling, you could reach in the throttle bore and block the iac passages, see if there is an effect on the idle. There should be a big effect. If no effect suspect a vacuum leak or the throttle valve is hung open. In the past, I have used my finger to block iac passages on a six cylinder vehicle, different make and model. Using your finger probably isn't a good idea, the vacuum is fairly stout.
Old 07-12-2010, 05:10 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Dave
Welcome to AF on your first post.
You have posted in the Blazer problem forum.
Best to post in the Saturn forum for help on it.
MT
Old 07-13-2010, 02:10 AM
Im sorry. Would a Mod be so kind as to move it in the right area? thanks. the car did it again. The vacuum on the PVC valve, and throttle body seem good. What else can I try?
