Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 05-13-2003, 01:25 PM
detoX's Avatar
detoX detoX is offline
turbo info!
im planning to get a turbo soon on my 2001 civic..so i thought i need to know more about turbos, so guys help are there kind of turbos?(maybe a like of lits of turbos would be great) i know they have sizes and all..and i think on my car i can only get custom turbos so guys..like are there any do's and dont's about custom turbos and what do you suggest i get? THANKS!
Old 05-15-2003, 01:05 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Well, I think you mean custom kits, because you pretty much put any turbo you want on your car. It is all a matter of oil lines, intake, piping.
As for sizes, what do you want? Do you want a turbo that is going to spool quickly and dish out the boost fast but run out of steam? Do you want one that will spool slower but give you better top end? Or do you want one in between?
As for as what kind of turbo, only use Garrett, they are the best. They OEM out to other companies like Drap ande Greddy.
Old 05-15-2003, 01:18 AM
Thor302's Avatar
Thor302 Thor302 is offline
well you if you want a turbo that will work well, youll have to get a compressor map and do a whole bunch of math to find wich one will be the the safest and one that will give you the most power, not just any turbo will work. for civics a t3 or t4 from turbonetics will probably be the best, if you can find the june issue of sport compact car there is a great write up on turbos! although a turbo kit from HKS or Greddy will be the easiest way to turbocharge your civic!
Old 05-15-2003, 07:33 PM
casperGSR's Avatar
casperGSR casperGSR is offline
Send a message via AIM to casperGSR
if you do want to go with a T3/T4 turbonetics turbo, which I have and recommend, look into DRAG they make kits for most honda apps and use the turbonetics turbo.
Built and boosted...
"I feel the need.... the need for speed!"
http://www.automotiveforums.com/img.php?313283teggie2.JPG
Old 05-18-2003, 01:26 AM
ssshhhh (_burn_)'s Avatar
ssshhhh (_burn_) ssshhhh (_burn_) is offline
Send a message via AIM to ssshhhh (_burn_)
drag blows. dont get it. ive seen a drag kit on an si and its SLOW>
based on the knowledge you've given ide say it would be best to buy a kit if you want to go turbo (which i dont think you should). revhard makes a kit for the si which is a great kit. you can run lower boost on the stock internals and get good results. revhard is the best mainstream turbo kit provider. period.
6.7 @ 211mph whooping kubo's ass all over the track
Old 06-06-2003, 11:42 AM
4bngr 4bngr is offline
Send a message via AIM to 4bngr
To my knowledge, no one makes a kit for the 2001 civic. So pretty much anything you decide on will have to be a custom job.
Judge not, lest you be judged first
Turbo Site - Lots of Turbo Info Boostology Camaro Discussions 0 08-03-2009 12:01 PM
useful turbo info for dsm! turbo2nr Off-Topic 2 08-01-2003 10:45 AM
911 Turbo info TimSalewsky 911 2 06-01-2003 04:52 PM
Turbo info Dumahim DMC-12 2 04-06-2003 12:15 PM
Ok, need help with turbo info... (boost - compression) sparq Forced Induction 4 03-11-2002 01:17 PM
