Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-12-2010, 12:29 AM
spenser spenser is offline
Question Speedometer not working
A friend has a 98 eclispe. The VSS sensor came apart had a heck of a time getting the lower gear out of the transfer case (Manual Tranny). Put a new sensor in still no speedometer. When placed new one in vehicle it dropped right I would have expected the gear on bottom would need to be turned to match it to what ever gear drives the VSS gear. Does anybody have a diagram of how the VSS is driven by what ever gear inside the transfer case. I am putting it up on a rack tomorrow with a volt meter attached to confirm if there is a signal coming from the VSS.
Thanks
Old 07-24-2010, 08:22 AM
Exclamation Re: Speedometer not working
pulled the VSS and hand spun the gear. I t shows signal to the PCM. Doesn't anybody have a diagram showing how it engages in the transmission?
