Old 07-11-2010, 11:32 PM
ilovemy2brats ilovemy2brats is offline
Help with these codes/transmission?
I have a 1997 Plymouth Voyager.
My transmission seems to be acting up lately.
My brother scanned my car and the codes/readings he got were:
P0720
Output Speed Sensor
P0734
Gear 4 ratio incorrect
P0733
Gear 3 ratio incorrect
P1698
Manufacturer controlled & axillary outputs
P071
o2 sensor
P0700
Transcontrol malfunction
I am wondering if this is a sensor problem or an entire transmission problem. Thanks for any help!
Old 07-12-2010, 03:53 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Help with these codes/transmission?
First I would reset the codes and see which come back. Gear ratio codes can indicate clutch wear. Have a shop read the CVI numbers. My book says P1698 is no CCD data bus signal from PCM. May have the common solder joint issue at the instrument cluster circuit board.
P0700 is only saying you have a transmission problem. It's a catch all to tell you to have the tranny checked using a specialised tranny scanner, the same used to read CVI numbers (Clutch Volume Index). The output speed sensor is easy to change. It's installed on the front right side of the tranny near the linkage yoke. Costs about $15-$40. If it's bad your speedo will be erratic or dead.
What symptoms are you seeing?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 07-27-2010, 09:08 AM
fatjoey666's Avatar
fatjoey666 fatjoey666 is offline
Mine did exactly the same as yours. Change the input and output speed sensors and the Transmission solenoid. speed sensors are around $30 each and solenoid is $150. That fixed mine for a long time until the tranny just went out completely, but i have 200,000 miles on the original tranny, so I feel I got my money out of that one! Good Luck!
