Old 07-11-2010, 08:50 PM
mfb496's Avatar
mfb496 mfb496 is offline
A/c problems
High guys! My problem is that every time my compressor kicks in , the engine stalls. I thought it mite need charging so i put a can of oil in. This didnt work and the a/c blows cold as ever. IAC problem? I know this to be one of the major tune ups for a injected vehicle.
Old 07-19-2010, 09:56 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: A/c problems
Do you hear a screeching sound when the compressor kicks in? If so, the compressor is likely seized up or close to it. I'm hoping when you say you added oil to the A/C you really meant refrigerant. Too much oil can damage the compressor. You almost never have to add oil, and if so it is usually included with the recharge can of refrigerant and will be labeled so.
If the comporessor is okay, then check the idle air control assembly. There may be a fautly A/C idle up relay or IAC valve stuck closed due to carbon buildup.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 07-27-2010, 02:40 PM
mfb496's Avatar
Re: A/c problems
I'ts not staying on at all now. This is a drive by wire setup and recently changed the battery but not the exact replacement. Trying to remember if i used the a/c after the battery swap.
