Crank pulley bolt thread size??
Need a little help. 2000 Grand Prix GTP (Daytona pace car edition).
I had the classic crank position sensor symptoms, so set out to change it today. After pulling the vibration dampner, I replaced the sensor without a hitch. I started re-assembling, and found that the puller I used had boogered up the outer 1 or 2 threads of the bolt hole (in the end of the crank) that holds the dampner on. Before I take a rotory file to the threads to try and clear the bad thread(s), I thought I might try running a tap in there to clean them up. Does anyone know what thread size that bolt is so I can make sure I get the right tap? Any help or advice would be greatly appreciated ..... Last edited by jatchis; 07-11-2010 at 09:20 PM. |
Re: Crank pulley bolt thread size??
3/4"x16 thread
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
Really?? Wow, I thought it was a metric thread. We may actually have that size up at the shop. |
that's what the GM computer shows. I figured it would be metric as well.
according to the second post in this thread, they are metric bolts
http://www.grandprixforums.net/f95/a...cer-13775.html
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM, 1981 Fairmont 6cyl 3 speed 1978 Ford Ranchero GT 302 with a few goodies |
Are we talking bolts you thread into the crank pulley to pull it off, or are you actually asking about the actual crank bolt in the center of the crank?
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
I went up to the race car shop, we have a tap/die set that includes 3/4-16, and that size die threads onto the crank bolt, so I will be trying to clean things up with the 3/4-16 tap after I finish my coffee this morning ... |
Happy to report that I got her on the road again.
Thanks guys!! |
