Old 07-10-2010, 10:43 PM
dburn08 dburn08 is offline
Geo starting problem
ok i swaped a bad 1.0L engine out for a lower mileage one now the car wont start battery is good all electrical connectors are plugged in car has electrical power when you turn the key u can hear a faint clicking noise but only once the starter was checked by advance auto and they said it was good any help would be great
Old 07-12-2010, 05:23 AM
redpepe redpepe is offline
Re: Geo starting problem
you say all elec connectors are good but specifically check all the ground connections to the engine. try carefully jumping a ground wire to the starter body.
good luck.
Old 07-13-2010, 05:03 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
You need all the sensors, etc. from the original engine, some things changed without looking different, especially the distributor. If your car is newer than 94, you need a crankshaft sensor between the oil pan and the accessory drive pulley. As redpepe said, the main ground underneath the intake manifold is missed by many when changing engines.
Oh, maybe I'm answering a question that wasn't asked, now that I re-read, it sounds as if it doesn't even crank. There's a shim on some starters that keeps the gear teeth aligned properly, and automatics have a different starter than manuals.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
