Go Back   Automotive Forums Car Chat > Kia > Sportage
Old 07-10-2010, 05:56 PM
hollywdmarine hollywdmarine is offline
Check Engine Light
my check engine light come n and off. ive narrowed it down to when the gas tank is half empty to 1/4 the light stays off?/ ive chnaged the gas cap twice. i saw a post that suggest the fuel tank pressure sensor? or maybe should i open it up clean out the pup and anything in the tank?? .also one post suggest fulel vapor line being checked and how would that be done?? this is a 1998 kia sportage
Old 07-12-2010, 11:56 AM
LMP's Avatar
LMP LMP is offline
Re: Check Engine Light
ALl of the above are relevant. It would have been interesting to have the code read .
THe pressure sensor connector is accessible from the trap under the rear seat. this sensor is analog
From the shop manual available at www.kiatechinfo.com : (test is made witn connector installed and engine running. )
4. Using a voltmeter, measure voltage at all three Fuel Tank Pressure Sensor terminals in the fuel tank sending unit connector.
WHT/BLK - 2.0 - 3.0 V (signal return voltage/base reading)
If signal voltage reads 5.0 volts, check the sensor ground wire.
GRN/YEL - 0.0 V (sensor ground)
YEL/GRN - 5.0 V (reference Voltage)
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
