Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Bolt on Parts
Old 07-10-2010, 04:39 PM
Cavalier9696's Avatar
Cavalier9696 Cavalier9696 is offline
Send a message via Yahoo to Cavalier9696
Tach Adaptor
IM wanting to hook up a new tach in car, but the 95's have to have a tach adaptor from what I was told. Where is the best place to get one and what do they look like.
1995 Eclipse RS 5psi
Garret T3/T4 Turbo, Procharger FMU, TurboXS BOV, OBX Evolution 35mm External WG, HKS Intercooler, Apexi DP, Apexi exhaust.
Old 07-18-2010, 09:39 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Tach Adaptor
You cant just tap into the rpm wire coming from the ECU? I would try that first but if it doesn't work MSD probably has something
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-17-2010, 04:31 PM
Re: Tach Adaptor
Good idea. How will I go about running down the tach wire? Or the easiest way. Maybe my haynes book?
Old 11-18-2010, 10:09 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Tach Adaptor
Haynes doesn't have it.
Pull the plastic cover off the ECU and look at the harness and wires. The harness has numbers on it along the top/bottom. Should be 1, 21, 41 and the other side say 20, 40, 60.
Count from wire 1 and look for wire 8. Should be a solid white wire. That's the signal to the tach. You can splice into that one. Solder the wire on and tape up. Reinstall ECU wire cover.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-18-2010, 12:34 PM
Holset powered 420a
Re: Tach Adaptor
http://www.2gnt.com/index.php?d=1995_ECU
98 Eclipse GS Turbo
2001 BMW 325i - DD
