Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 07-10-2010, 08:58 AM
ITSWRONGWAY ITSWRONGWAY is offline
abs brakes
the abs light came on . how can I check to see what wheel is sending the bad code without going to a dealer and paying through the nose to plug into the system ? ( 01 escape 3.0 4x4 )
Old 07-16-2010, 03:16 PM
65comet's Avatar
65comet 65comet is offline
Re: abs brakes
Call your local parts places to see if they have a loan-a-tool program and if they have the code reader for brakes. You can do a visual check for some things. See if the anti-lock gear around the CV has any missing teeth. See if it is loose or out of place. See if the anti-lock sensor is loaded with metal fragments/shavings (it is a magnet). See if the sensor wire is broken.
Old 07-16-2010, 03:34 PM
Off_Timing Off_Timing is offline
Re: abs brakes
ABS light can also be activated by a low brake fluid level condition. Top it up right to the line of it's low.
I would look at that first.
