Old 07-10-2010, 06:46 AM
emc73 emc73 is offline
03 voyager tranny problem
I have an 03 Chrysler Voyager with 3.3l and auto trans with 59k on it. Its not driven alot, once a week, and the 4-3 downshift has a hard bump now. The fluid has recently been changed, and no warning lights. What could be causing this? Any help would be greatly appreciated.
Old 07-10-2010, 11:24 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 03 voyager tranny problem
May want to swing by a tranny shop and have them scan the Transmission Control Module (TCM) for transmission fault codes and check the Clutch Volume Index (CVI) numbers. The CVIs indicate clutch wear. It takes a special scanner to do it. This could be an internal problem or a problem with the solenoid pack. If it's the pack you can DIY it. A new pack runs around $150. If it's internal it's time for a rebuild. You changed the filter and used ATF+4 fluid correct?
Did a little pokin around. There is a TSB published for your specific problem for 2003 Chrysler minivans. It's number 21-006-03 and involves reprogramming the TCM. Just can't find the narrative for details.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 08-23-2010, 12:04 AM
So update on the trans. I took it in to the dealer, they did a diagnostic on it, no codes, AVI numbers came back ok. They did do the update, and that seemed to fix it. Thanks for your input RIP!!
Old 08-23-2010, 02:07 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Glad to hear it and thanks for posting the fix. Buy me a beer sometime...
