Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-09-2010, 09:52 PM
SteveCooke101 SteveCooke101 is offline
Leaking what looks like coolant...
Wondering where to start? It looks like there is a faint blue gasket material that looks worn out where the leak is showing. Is this a gasket replacement or worse? Any help would be greatly appreciated. (sorry if its vague) Thanks!
Steve
Old 07-10-2010, 06:51 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Leaking what looks like coolant...
If you find there's coolant near the blue sealant, it most likely dripped down from the water pump just above. Feel around the bottom of the water pump while the engine is cool and see if your hand shows wet.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 07-28-2010, 03:46 PM
kevinb70 kevinb70 is offline
Send a message via AIM to kevinb70 Send a message via Yahoo to kevinb70
but coolant passes thru the timing cover.... can be leak from timing cover, or the bypass hose near the top/front of the engine, or thermostat housing. all common low volume leaks.... in addition to what was posted.
1999 Dodge Ram 1500 2WD 5.2L NV3500
1998 Chevy Lumina 3.1L (2010 DIY intake/head job, 2011 DIY A/C replaced, ran like a top til I sold it in 2014)
1999 GMC Sierra 4.3L
2014 Toyota Prius Four
Old 08-01-2010, 11:07 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Steve, you didn't say what year your truck is, or how many miles.
I'd suspect the bearings in the water pump first. There's a weep hole on the front of the water pump, which is designed to start leaking when the water pump is starting to go.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
