Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 07-09-2010, 08:36 PM
94lincolntowncar 94lincolntowncar is offline
Exclamation 94 Lincoln Town car stalling
Hey all,
I'm having a problem with my 94 Lincoln Town Car losing power and hard to start. These are the symptoms I'm having
1. Hard starting- Engine just turns over and over. Car WILL start after about two to five tries
2. It then cranks but cuts off after 1-2 seconds. Will only stay cranked if you're pushing the gas pedal
3. After driving for a few miles car losses power and engine starts to bogg down. If you press harder on the gas it makes a gulping/backfire sound from under the hood. If I put the car in neutral and switch it back on while it's still rolling I'll have power back for another half mile or so.
Things I've replaced to try and fix the problem:
Fuel Filter
Fuel pump
Spark plugs
PCM
I know the car is getting fuel to the fuel rail because I checked that and even though there's fuel to the fuel rail it still just spins over unless you keep trying it over and over and pump the gas. Please help
Old 07-09-2010, 08:50 PM
All2kool's Avatar
All2kool All2kool is offline
Re: 94 Lincoln Town car stalling
Originally Posted by 94lincolntowncar View Post
Hey all,
Fuel Filter
Fuel pump
Spark plugs
PCM
MAF Sensor or Crank Position Sensor is what I would look at next.
Old 07-09-2010, 10:48 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Agree with all2kool. Also are you sure the cats aren't clogged?
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 07-10-2010, 09:23 AM
All2kool's Avatar
Excellent suggestion.
Old 07-10-2010, 04:18 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
I'm not sure if this applies to the '94 TC, but my '95 had the same problem and the way I fixed it was cleaning the EGR passages/channels under the air intake elbow, here's a link with more information about it. Hope this helps.
Cleaning EGR passages
Old 07-11-2010, 10:22 AM
Just to be clear, by cats you mean catalytic converter? haven't checked that. And I'll clean the EGR passage then I'll change the MAF and if that doesnt work the crank sensor. Will keep you updated. Thanks
Old 07-11-2010, 10:35 AM
Replacing the MAF can be expensive. Clean it instead using CRC MAF Cleaner. Unless you can confirm it is faulty.
And yes I mean catalytic converters.
Old 07-11-2010, 01:46 PM
All2kool's Avatar
True, MAF's are spendy and if you have a BMW, they can be $700; believe it or not.
