Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-09-2010, 05:11 PM
gbusby gbusby is offline
Out of gas but gage reads 1/4 tank
Is the fuel level sender in a 98 Mustang Base part of the fuel pump or is it seperate?? I have searched for the part and the only level senders I can find are generic replacements. Some fuel pumps indicate that they provide level sending as well.
Old 07-15-2010, 03:41 AM
mikesheldon mikesheldon is offline
Re: 1998 Mustang Base 3.8L Fuel Sender
It should be in your trunk by your left tail light.If it is an electronic pump, it is supposed to come on and then stop once the fuel pressure has been reached. Does it run or have you tried to start it
Old 07-15-2010, 08:06 AM
I think I wasn't clear enough in my post. My fuel gage indicates 1/4 tank when i run out of gas. I tried searching for a new fuel level sender thinking i simply needed to switch it out. But when I searched for the part, I keep getting a fuel pump. Sometimes the specs on the pump mention the level sender and sometimes it doesn't. So what I need to know is, do I have to change the fuel pump to correct the eror in the fuel gage??
Old 07-15-2010, 06:32 PM
97Bird's Avatar
97Bird 97Bird is offline
The fuel level sending unit is part of the fuel pump module. $$$$! Price ranges from about $200 to $400 depending on where you buy it.
The Original 97Bird
Tags
fuel , level , sender
