Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 07-09-2010, 04:48 PM
coldday coldday is offline
Loose Skid Plate...
The skid plate on my 99 Rodeo is loose. There are 4 bolts and washers that mount it to the front frame. Most of the threads appear to be stripped to varying degrees. I like to blame a quicky oil lube place long ago for that.
Question: easiest way to rectify?
1) drill out and re-tap to next larger size? (not very easy, requires tap)
2) buy next size bolts and torque those in
3) ?
Any thoughts/suggestions appreciated. Thanks.
Old 07-11-2010, 07:44 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Loose Skid Plate...
I would start with buying the same size bolts and see if that fixes it.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 07-14-2010, 05:45 PM
5throdeo 5throdeo is offline
3) ?
To me there are 4 ways to go---try much shorter bolts--if you can do it buy smaller bolts w/ lock washers and nuts ,put them thru the holes and put the washer and nuts on the smaller bolts--if you don't drive off road just leave it off--the one i would do is buy a thread tap for the threads and retap them, install new bolts.
