Old 05-13-2003, 02:24 AM
ef302's Avatar
ef302 ef302 is offline
evo5
hows this scale burnout for ya's :frog:
Old 05-13-2003, 02:47 AM
Tomaszken's Avatar
Tomaszken Tomaszken is offline
Nice .... but I think the car won't do a burn out without driver
Check My RC cars here
Old 05-13-2003, 02:50 AM
njh njh is offline
Sweet, did you use cotton wool to make it?
Old 05-13-2003, 03:02 AM
ef302's Avatar
that right
cotton wool i was taking some pick this arvo and thought id give it a try.:smoker2:
Old 05-13-2003, 07:42 AM
ozstrider's Avatar
ozstrider ozstrider is offline
Arent EVO's rear wheel drive?
Pretty cool effect though.:sun:
Old 05-13-2003, 07:45 AM
freakray freakray is offline
AF Modelrater
No, they are AWD, so unless the torque splitter is set way forward, it wouldn't burn out only the front wheels.
AF User Guidelines
Old 05-13-2003, 08:25 AM
nervestrikes's Avatar
nervestrikes nervestrikes is offline
That was a really cool idea and it looked great as a burnout!
Old 05-13-2003, 08:54 AM
flyonthewall's Avatar
Car Mod guy
Nice model, personally dont like the rims though.
Old 05-13-2003, 09:06 AM
irupp33's Avatar
irupp33 irupp33 is offline
Send a message via AIM to irupp33
actuallyi was gonna ask if the rims came with that kit. there pretty cool!
1991 Eclipse GS-T
Exterior: stock
Interior: Boost and A/F gauge, TV/DVD player, thats about it.
Motor: supra side mount, hard pipes, greddy type s, greddy profec b b/c, nology hotwires, 3 in. turbo back exhaust.
Wheels and tires: stock shitty fan rims with stock tires (no grip what so ever)
Old 05-13-2003, 09:10 AM
srlxy srlxy is offline
No they are 4wd...
There is a difference in 4wd and AWD...
Just my 2cents...
no offence...
Old 05-13-2003, 09:29 AM
AF Modelrater
Originally posted by srlxy
No they are 4wd...
Just my 2cents...
no offence...
Explain the difference in your opinion.
The are full-time four wheel drive....hence AWD....
AF User Guidelines
Old 05-13-2003, 10:04 AM
stubacca's Avatar
stubacca stubacca is offline
Send a message via ICQ to stubacca
Looks like a nice clean build. Burnout looks pretty cool. Would look better with a touch of rear wheel smoke as well, though you'd need a bloody high power EVO to do a burnout in a straight line!!!!
btw 4WD doesn't have a centre diff meaning it can only run in 4WD on loose surfaces (eg early Landcruisers, Explorers etc). AWD has a centre diff (eg EVOs, Subarus, Range Rovers). The centre diff prevents wind up on high traction surfaces by allowing the front and rear diffs to spin at different rates.
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved piece, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
WOW... WHAT A RIDE!
Old 05-13-2003, 10:19 AM
Ok,
The new subaru was said to be AWD...
Being puzzled to why it was called AWD and not 4WD, I went around asking and the most stupidest answer I got was
For AWD, Even the spare tire in the boot moves...
So I went around and decided it was best to ask the Subaru dealers...
Here's the catch
4WD, power to rotate the wheels are distributed evenly to all four wheels... Example, if there was 40, each recieve 10...
AWD, power to be distributed to all four wheels vary, according to conditions, thats y if you notice, only Subaru calls their car AWD for those newer models.
Others call their models 4WD...
Hope it helps....
I could be wrong though...
Old 05-13-2003, 02:14 PM
Blowncivic1320's Avatar
Blowncivic1320 Blowncivic1320 is offline
Who Makes those rims they are REALLY cool lookin (not the best for THAT car tho )
-Andrew-
Old 05-13-2003, 02:26 PM
AF Modelrater
Ok,
Here's the catch
Hope it helps....
You're wrong again.....others don't all call it 4WD......for example, Toyota call it All-Trac and VW call it 4-Motion and Audi call it Quattro. When you look into it though, it is all AWD.
In the Lancers, the power distribution is variable, as it is in the Audi and Toyota All-Trac's. They use a torque splitter to vary the power to the wheels so that the wheels with the most traction gets the greater amount of power hence maintaining traction and control.
I think you have been a victim of the Subaru marketing monster
Also, I think Subaru is the only one who uses it so greatly as part of their advertising drive.
AF User Guidelines
Evo5 jdmhotrod WIP - Street 19 07-17-2003 04:47 AM
Images Test Evo5 WRC Vric Car Modeling 12 05-15-2003 10:21 PM
Evo5 progress pics UKSupraboy Car Modeling 26 12-04-2002 01:05 AM
Final Evo5 Pics **Warning - Image Intensive** UKSupraboy Car Modeling 18 11-27-2002 08:59 AM
Is it possible to put the Evo5 front end on the Evo7? rupertaker Lancer 2 05-19-2002 09:08 AM
