Old 05-12-2003, 11:16 PM
blade34609's Avatar
blade34609 blade34609 is offline
Alternator Replacement?
Hi,
I have a 1990 Honda Civic LX and I am going to replace my alternator with a new one.
I was told it is easy to take off the old one and put a new one on.
But the problem is with the honda engine bay is very small to get to the alternator.
I am going to replace it hopefully tommorow.
I have the Haynes manaul on how to do this and it seems pretty str8 forward.
Thanks,
Owen
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 05-13-2003, 11:36 AM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
It seems straightforward, but it's actually a wrestling match.
One fellow here recommends taking out the driver's side axle. Which does make it easy, but if you've just bought the car, then that axle nut is probably really tight. I had to go to a shop and let a friendly guy with an air impact loosen mine.
I changed my alternator without doing that. It's easy to get the alternator off. What's hard is getting the old one out of the engine bay and the new one in. It took me an hour.
Another fellow here says it's easy if you take off the splash guard and remove the alternator bracket as well.
I didn't do either of those things, just wrestled, swore, and nearly gave up. Be prepared for the $100 (Autozone) price of a new alternator, and a $50 core charge.
And don't believe everything you read in those manuals. Sometimes there's a much easier way than the one they suggest.
There are numerous threads dealing with this topic. Check 'em out, and good luck.
Flunky
PS-Welcome. You made a good choice for your new ride. Exactly like mine. You can see it under the 'Pix of My LX' thread.
Old 05-13-2003, 02:45 PM
AF Premium User
Hey, Blade!
I found this gem at the end of another post on this topic. It says:
Wait I have a 91 hatch and I have found a really easy way to get this out. All you have to do is disconnect the alternator drop it down onto the engine bay and slide on the bottom of the engine bay from the drivers side to the passengers side. It then just slimply slipping it out from around the hoses and then you got it.
(that was by 91Bluedx)
Give it a shot!
Flunky
alternator replacement, help please? blsbrandy Windstar 19 10-03-2009 07:00 AM
1996 Alternator Replacement…. josh0351 Altima 2 07-05-2004 12:04 PM
s10 Pickup, Alternator replacement [email protected] S-10 2 09-04-2003 11:58 PM
alternator replacement komatiite '88 - '91 Civic | CRX | Wagon | Shuttlee 8 06-16-2002 04:26 PM
Alternator Replacement warmonger Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 22 11-30-2001 12:24 PM
