Old 05-12-2003, 10:37 PM
JDM00CivicEX JDM00CivicEX is offline
speedometer acting crazy
my alternator gave up on my 2000 Civic EX Coupe so i installed a new one and i also put in a new battery today, now when im driving, my speedometer goes crazy, like it will jump to 120 MPH then go back to 0 MPH and so forth and it does not show me the right speed that im actually going at, so does anyone know how to fix it or know wut might be the problem??? thanx
Old 05-13-2003, 04:29 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
does this happen when you are driving, or at idle?
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-13-2003, 05:35 PM
sometimes at idle it will jump, but this mostly happens when im driving.
Old 05-13-2003, 07:54 PM
TheRebirth TheRebirth is offline
Banned
lol, get your buddies to ride in it
"HEY GUYS! LOOK! 0-100 in 3 SECONDS! w00t!"
Old 05-13-2003, 10:35 PM
SiRII's Avatar
SiRII SiRII is offline
i got that problem too. except when i hit 50 mph. it jumps to 80 mph.
Old 05-14-2003, 11:43 AM
tEk4000 tEk4000 is offline
its probably your speed sensor, this is located on top of your transmission, it's quite expensive, 200~250 or so. good luck
Old 05-14-2003, 12:59 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
check your ground connections.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 05-14-2003, 08:30 PM
Drift King's Avatar
Drift King Drift King is offline
I think it might be an electrical problem. Im not sure but I think your spedo works like the tach, different voltage for changes. Therefore you might have to recheck your instal, bat., ect. If that doesnt work you might want to check with a professional. Who knows what other stuff may be going wrong that you cant see.
EJ8
SHUMI-ROSSI-2007-F1 FERRARI DREAM TEAM
Old 05-14-2003, 08:38 PM
crxlvr's Avatar
also check your TPS and the idle speed sensors.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-18-2003, 07:14 PM
wagsaccordsir's Avatar
wagsaccordsir wagsaccordsir is offline
Check your the connection on your alternator, ennsure that it is tight. Pull the rubber grommets back and wiggle the wire, if it moves tighten it.. This may or may not fix your problem, but this same thing happened to me on the way to a show yesterday. It was almost as if I had went through an electro magnetic shield.. LOL Gauges went haywire, stereo flickered, everything just went crazy as if they had a mind of their own. I got out and checked my battery terminals, they were tight. I then grabbed the wire that goes from the alternator, over the valve cover and to the back of the block. When I touched it, my engine bogged down and almost died, when I let go it revved back up, and I did this repeatedly, confirming that was the culprit. Upon peeling back the rubber grommet, and wiggling the wire it was in fact loose. When I went to tighten it, it dissentigrated, thing broke into a million pieces... LOL I was fucked and in the middle of nowhere, I had to call a buddy of mine over an hour away to bring me new alternator.. Anyway made the story too long, but just check it out.. Other than that, check your grounds, if you have stereo equipment pull the fuse, as that too may be grounding out somewhere...
MY ACCORD ON KENWOOD'S PHOTO GALLERY
MY ACCORD ON CARDOMAIN
"CHEAP THRILLS"
I DON'T CARE HOW MANY SKY DIVES YOU'VE GOT. UNTIL YOU'VE STEPPED OUT INTO COMPLETE DARKNESS AT 850' WEARING 95LBS. OF EQUIPMENT AND 68LBS. OF PARACHUTE. YOU JUST HAVEN'T LIVED.
ARMY AIRBORNE!!!
acting crazy Sgt2106 Durango 2 02-17-2011 07:56 PM
1996 Sunfire won't start. Dash acting crazy seedpws Cavalier Problem Diagnosis 4 05-16-2006 02:30 PM
2002 Dodge Durango is acting crazy sherry8707 Durango 3 09-26-2005 08:46 AM
91 Cavalier - All the Gauges acting Crazy! zerokarma Cavalier 2 07-08-2004 02:34 PM
Truck acting crazy paixbouche C/K 3 01-29-2004 12:41 PM
