No headlights??
Working on a '98 windstar 3.8.No headlights!?!? Headlight switch tested good but still has no high or low beams.Has high beam flash dash lights and parking lights.Checked ALL fuses in both boxes.Any help would be greatly appreciated!
Re: No headlights??
ok, not trying to be a jerk here but the bulbs are good right? Did you put a meter across the plug to see if there's voltage at the connector?
----------- 2000 windstar 3.8 2010 honda pilot touring Muskoka Canada |
Re: No headlights??
High beam flash works and there is no power to bulbs otherwise.Bulbs are good.Thanks!
Re: No headlights??
It might be the headlight switch......which includes the circuit breaker (self resetting) for the headlights.
My headlights started to blink a bit when I turned them on....very intermittent....... Also, my headlight switch was warm after running the headlights.....NOT NORMAL. I replaced the headlight switch.....pictures of the process are posted (I did it at the same time as I replaced my "multifunction" switch due to the right turn signal getting flakey). After I replaced the headlight switch......no more blinky and no more warm switch.
Moderator for Ford Windstar room only Links to my pictures, intended as an aid, not a replacement for, a good repair manual. 1996 3.8L Windstar http://www.flickr.com/photos/4157486...092975/detail/ 2003 Toyota Sienna pictures (not much there yet) http://www.flickr.com/photos/4157486...781661/detail/ |
