Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 05-12-2003, 08:51 PM
syne164 syne164 is offline
waterspots
wash car and then wax with 3m hand glaze after that used collinite wax but i still have swirls and alot of water spots mostly on the roof and the trunk & spoiler please help ? what can i use?
Old 05-12-2003, 09:13 PM
97wvmax 97wvmax is offline
Send a message via AIM to 97wvmax
grandad has same prob, he thinks his spots are hard water and he hasnt found a way to get it off!
Old 05-12-2003, 09:49 PM
thrasher thrasher is offline
Re: waterspots
first off, i don't use anything except megiuar's. it's the best shit, and only a couple bucks extra, but worth it. as far as the water spots, get a california water blade (the original, with medical grade silicone) and wipe down the car immediately after you wash it, this means that NO PARTS CAN AIR DRY...if need be, keep the whole car wet before you wipe it down. when waxing, only apply the wax and rub off following the lines of the car, that way if the wax does mark a little bit, they will follow the car's lines. good luck!
"Don't have sex man. It leads to kissing and pretty soon you have to start talking to them."
Steve Martin.
Old 05-13-2003, 12:55 AM
wax
collinite carnauba wax is one of the beat and it's not cheap $30.00 or more for a can?
Old 05-13-2003, 09:04 AM
NJMAXSELTD NJMAXSELTD is offline
You need to clean your paint of the embedded water spots before you wax it. Use a 3M fine cut cleaner followed by a polish to bring the finish back up and then apply wax to protect your newly cleaned and polished finish.
99 SE LIMITED - A few changes here and there but most of all SPOTLESS!
Old 05-13-2003, 11:59 AM
wax
what polish should i use
Old 05-13-2003, 12:09 PM
wax
so i can use a fine cut cleaner to get at the waterspots and then use 3m hand glaze and then collinite wax is that kool?
Old 05-13-2003, 08:02 PM
PrinzII PrinzII is offline
Send a message via AIM to PrinzII
Re: wax
What is the condition of the paint? If it's in a reasonably good shape, you might be able to use something like Klasse All In one to get the water spots out.
Old 05-13-2003, 11:24 PM
collinite & squeaks
has awaybody used collinte products? im confused about what to use please help the paint is still new on the car it's 2001 and also when i roll the window up and down they squeak the two front one's what can i used to correct the problem i have factory tint ? thanks
waterspots on black rod1234 Cars in General 1 06-07-2005 11:57 AM
Waterspots on windshield???????? Rockey Cars in General 2 09-24-2003 03:33 PM
Waterspots slickkedar Cosmetics 4 08-02-2001 07:13 PM
