Old 05-12-2003, 04:26 PM
pod pod is offline
power to weight and torque
wahts a good power to weight ratio. my aspire has a 12.8 to 1 ratio
835lb 65 hp also whats a good torque rating for a light car like that
30 mpg in a brick on wheels isnt half bad...
Old 05-12-2003, 05:29 PM
2strokebloke's Avatar
2strokebloke 2strokebloke is offline
In Stereo where available
There's no way your Aspire weighs 835lbs. My Subaru 360, which is smaller and air cooled weighs 925lbs. I think you're missing a 1 from that number 1835lbs. So you've got 1hp per 28 lbs. of car. I think that the old rule of thumb for muscle cars was 1hp per 15lbs. of car.
Support America's dependence on foreign oil - drive an SUV!
"At Ford, job number one is quality. Job number two is making your car explode." - Norm McDonald.
If you find my signature offensive - feel free to get a sense of humor.
Old 05-12-2003, 11:44 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
carpoint puts the aspire in the neighborhood of 900kg, 63hp...
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 05-13-2003, 05:07 PM
pod pod is offline
1984lb? it feels lighter than that and its 65 becouse I took out the cat. my frend claimed that there was a car that did 6 to 1
Old 05-13-2003, 05:37 PM
1835lbs. sounds right to me, my Yugo which is about the same size weighs in at 1850lbs. I'd doubt it'd be much more lighter than 1800lbs.
Old 05-16-2003, 08:06 PM
pod pod is offline
they could have used thin aluminum who knows
Old 05-17-2003, 11:12 AM
Steel's Avatar
Steel Steel is offline
thin aluminum is weak. And ford generally tends not to use aluminum.
Ah. there we go. Curb weight of the 94-97 aspire's are 2007-2053 pounds. http://auto.consumerguide.com/auto/u...fm/id/2157.htm
Old 05-25-2003, 03:15 PM
454Casull 454Casull is offline
I couldn't help but laugh when you said you gained 2HP because you took out the cat.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 05-25-2003, 03:42 PM
Taking the cat out doesn't really do much of anything, in fact for the first generation tercels, the engine with the catalyst equipment makes 60hp, and the one without it make 62hp.
Old 05-27-2003, 07:16 PM
pod pod is offline
that sounds about right anyway i had a doubble cat
Old 05-27-2003, 09:43 PM
pod pod is offline
btw thats a custom exost
