Old 05-12-2003, 02:35 PM
detoX's Avatar
detoX detoX is offline
apexi
is the V-AFC anygood? what is it primary used for? can they increase power? cause some mechanic told me that their good for nothin..their just for show..it that true?
Old 05-12-2003, 02:38 PM
SiRII's Avatar
SiRII SiRII is offline
that's wrong. you can control your vtec and run rich air fuel mixture.
Old 05-12-2003, 02:43 PM
detoX's Avatar
is it hard to learn to use it?
Old 05-12-2003, 04:35 PM
SiRII's Avatar
i think the instructions are in japanese. i can't remember if it's in english. but, it's easy to use.
"The V-AFC features a user-definable, eight-point, adjustable fuel curve that can be set in 500 RPM increments. The range of fuel adjustment is 50% at each of the user-defined setting points. The Fuel Adjustment function considers wide/narrow throttle and low/high camshaft settings, from which four different fuel maps are created (wide-low, wide-high, narrow-low, narrow-high). The integrated VTEC Controller adjusts the point at which the engine switches from the Lo to Hi cam during acceleration, as well as when the engine switches from the Hi to Lo cam during deceleration."
Old 05-12-2003, 04:58 PM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
That's funny the way you copied that on there. Are you a spokesperson for Apexi?
Old 05-12-2003, 05:02 PM
SiRII's Avatar
well it explained it didn't it
Old 05-12-2003, 05:04 PM
B16EJ1's Avatar
Yeah but most people post a Apexi link instead of trying to sound like the mad scientist on the Fast and the Furious.:hehehe:
Old 05-12-2003, 05:06 PM
SiRII's Avatar
Old 05-12-2003, 05:08 PM
B16EJ1's Avatar
What?
Old 05-13-2003, 03:46 AM
BOOSTD's Avatar
BOOSTD BOOSTD is offline
Best thing to do is get it installed by someone who knows what they are doing. The mechanic that told you they are for show knows sweet f@#k all. They arent too hard to use but when you get it installed I am sure the mechanic will explain everything to you.
Old 05-13-2003, 07:50 PM
TheRebirth TheRebirth is offline
Banned
i heard they only useful if your engine's well-built.
Old 05-15-2003, 10:46 AM
detoX's Avatar
any feedback who has one whould be great guys. how does it increase hp? and what is it really used for..is it like used for cars that has turbo?
Old 05-15-2003, 11:23 AM
BOOSTD's Avatar
It doesnt increase horsepower. It basically allows you to tune your engine (control airflow, fuel etc) at the push of a few buttons. If correctly setup your car will run more efficiently and will be more responsive etc. The true potential will arise if your car is modified.
Old 05-15-2003, 12:51 PM
SiRII's Avatar
i believe that it does give you more hp. http://www.members.aol.com/ryoucold/...pexi/apexi.htm
Old 05-15-2003, 01:42 PM
liquid8 liquid8 is offline
Send a message via AIM to liquid8
it probably will if you have mods but that's the same as with any tuning. you will gain hp cuz tuning will extract the most hp out of a mod it can
"life's a bitch but god forbid the bitch divorce me" - nas
